  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Woo HOO I got my stickers today, and I think he packed in an extra so I got all 3 now :) might go home and wash those parts off and stick them on, as then it'll be sitting at Gav's for a while, might do a bit of advertising for the site :D although I think a lot of the people who go there are from here :D
smooth: too late. Just got back.. I was down there earlier. **** that area is a BROTHEL. I was paranoid about my car getting wiped out by trucks, crazy tradeys and god knows who else. Worst possible street for it, so narrow, no room for parking, etc and you can barely get into the actual workshop car area itself to park. Be very careful if you go down its seriously dangerous.
..but in good news..
NEW SIDESKIRTS!!
Ended up getting blitz ones as they fill the line a lot better and come down low like the front bar. Should look pretty tough onces its all fitted. Ended up being $350 which was a bit more than what I wanted to pay (was expecting $300), but as long as they come up nicely doesn't really matter.
Here is my amazing "artists" rendition.. Bit hard to picture them on though.
not too traffic island friendly though! going to have to watch that :D
thanx :D Photoshopping is kinda my gig.. but not getting me work in that area at the moment.
I am sure they will look much better once painted... i just kind of stuck them there (notice the sticks :)) I'm amped to go and find some panel shops now, just get it all finished and back to "normal". Will do that next few days. Its been some 3 months I've had to drive it along all stuffed up like that.
Going to chase some panel shops up this week. Hopefully book it in next week if I can. So not too long.
Wing stays. In fact once I get it all fixed up, may well be putting it up forsale -- so no point stuffing with it too much.
lol - yeah drifto style - if only the reality was so glamourous.. hence my sig :)
yeah, i know :) but just want something bit cheaper and faster -- and to make it faster would cost me another $5k, as its already maxed out really with the stock turb .. would like to buy a house soon and considering importing a couple of cars b4 the 15 year rule to turn a few quick bux -- if its at all going to be possible before they end it.
Would still be a nissan turbo - just more around $12k than $20k.
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
