  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Fronts only? Is that fitted? Keep your pads?
Sorry for the q's... It's coming up on my list of mods too...
Yeah fronts only, not fitted, doesn't include pads either.
Probably could have sourced them cheaper but I needed them done pretty quickly.
uhmm before i send all this stuff off to you, what exactly do you do with compyters:D
We sell computer hardware and assemble/fix computers, setup Networks etc etc
go here for link ... www.umart.com.au
yer mechanical are probably the best in my opinion, tho apparently you can be defected for a mechanical boost guage as you are bringing engine vacume through the firewall which is illegal???
can anyone shed some light on that?
I've heard something similar...
But, the old commos had an economy gauge in dash which read engine vacuum... And the old Mercs had vacuum assisted central locking... So there is a few arguing points...
for pads strutto, see the guy at brake distributors labrador, and get yourself a set of rb-74s
if your getting slotted rotors, these are the pads to get
i got em on my car atm, they only squeal a bit cause the faces get a bit glazed sometimes,
slip runs the same pads on his 31, and if uve ever seen that thing stop, ull definatly agree they are good pads
$520 isn't too bad for slotted..
If you can catch me unawares you can steal mine strutto :)
Belgarion: could be? But still, you'd have to be pretty unlucky to get defected for that. Haven't heard anybody in australia getting defected for that. But i'm sure a cop could try it. In VIC they tried "exhaust too big".. lol
nexus9 i know you assemble computers at umart, my friend buys em off ya,
i used to buy all my wintel pc parts at umart when i was into pc's but in those days, i had to drive to milton to get the parts too
mick51 from here used to work for umart too if i remember correctly, in the RA dept
Yah... rb74's are on the list... But gunna do rotors first... Should rotors be bedded in with new pads or old pads???
ann you work for umart, gotcha i know what they do..
Mate just a bit of advice for me here, if i was to head off to that field of work would i be able to get in without a MSA and the other thing. considering my other qualifications?
In all honesty cert 1,2 and 3 don't mean a hell of a lot until you take the step to sit for your A+. If you have those certificates then an A+ shouldn't be too hard.
You could still get in the industry by impressing me with your real life knowledge for example.
But I think a little more study may be in order.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
