  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
apparently its like 6 points for eating or drinking while driving.
That's a bloody outrage. :) That's the equivalent of 2 excessive noise fines on the old scale. The only reason you notice this is that it effects you. You would be amazed what sort of crazy laws get passed. Back when I was involved with Amnesty international you'd hear of both the major parties passing all sorts of laws that gave police and border control greater powers many of them being totally unjustified. The major parties would gag debate on the topic, and then the mainstream media wouldn't run with it. makes you wonder.
lol - it would be..
yeah, i was just thinking of buying a car for around $1000 that can get me around when i don't want to drive the skyline, and if i'm driving to the coast a few days a week. Will also come in handy when its at the panel shop being made to look sex again.
I've got a little more debt to go before I start looking for a cheap car. But after I got to drive an old subaru around the other night (soft suspension can drive over speedbumps at 30kph. Try doing that in a skyline) I really want something to drive to the shops or leave parked wherever for extended periods of time.
yeah.. sometimes its a real hassle driving the liner.. just worried some shit is going to happen to it all the time.. speed bumps, fools who can't drive, etc.
Ends up saving you money in the end really. By the time you look at the petrol costs, general wear and tear on the skyline, and everything else over a year or so, it doesn't really cost you much.
Hi James,
I think I left a forum page open at work yesterday when i locked my workstation, so it prolly seems like I'm logged in 24 hours a day.
Did you catch up with JL on the highway last night?
lol.. thats why i created this thread :D 'cause that one was degrading into a wasteland anyhow.. But you can go dig it if you like mindflux.
What did you do to your car Gordon?
door + truck.. months ago, i just haven't had a chance to get it painted as I've been too poor. But things are looking up so will get it done in a couple of weeks.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
