$1500.. all pretty straight and things.. has aircon, power steering, extractors, exhaust.. so not too shabby.
needs a new diff though (clunk, clunk), so that better not be too difficult to do..
Will post some pix when i actually get it (probably this weekend)
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Yeah I don't like Tom Cruise and if they had some one else the movie would have been even better and I would have most definitely have paid to see it sooner.
I saw it for the first time on a cough* dvd cough* last week and thought it was definitely worth going to see on the big screen and it was.
bit torrent?? eh?
uhuh:)
most movies are available long before they are released in cinemas here
and normally dvd rip converted to divx, sometimes dvd iso's are available not long after the dvd is released in the states
Absolutely going to buy the DVD when it officially gets released.
There hasn't been any GOOD Samurai movies for ages (western release that is), last one I can think of was the telemovie/mini series Shogun
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
