  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Hey guys if you can't be bothered downloading movies and games you can also get stuff like that by trading on here ... www.austech.info and www.eightmm.com
example.... three blank dvd's will get you a copy of "Butterfly Effect" on DVD (only just opening at the movies)
I think it will be much bigger than you think Erin,
there is probably a core group of over twenty now if Thursday are anything to go by, and once you have a critical mass then all sorts will come from the woodwork to join in
I would prefer to keep it to Skyrice Australia because if you start putting threads in boost's main street cruises and performance forums and qldstreetcar, you dont really know what type of wankers and their dogs are going to turn. Plus the no hopers who come along to ruin things.
But saying that, by all means if you know someone PERSONALLY from another forum who has a skyline, PM them and invite them along.
I just dont really have the patience for putting up with wankesr
yeah: wanker free = good.. otherwise the cops can turn up and then who knows what can happen.
best honest answer!! dun make promises that you cant keep
exactly! thats more along my line of thinking :D
i sent you a "read receipt" i think? i'm sure i clicked "ok"
$1500.. all pretty straight and things.. has aircon, power steering, extractors, exhaust.. so not too shabby.
needs a new diff though (clunk, clunk), so that better not be too difficult to do..
Will post some pix when i actually get it (probably this weekend)
$1500???? Skyline????
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
