  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Morning, and true about vnc, only thing is I prefer terminal services, now with microcrap's new remote desktop client, it is just way faster than any flavour of vnc I have tried, but hey vnc rocks for free! It is great cause I setup my mates computers and thier firewalls so whenever they have probs I tunnell though their firewalls and just take a look see :P Also sometimes take control and do funny stuff :D
Also, I can highly recommend Broadwater Brakes & Suspension as of this morning...
They fitted and balanced my Azenis to my rims in under 45mins for $20... I got there at 8.10am and asked if they could do it while I waited...
I was well looked after, undercharged (IMO) and would have no hesitation going back...
thanks strutto.. may keep it in mind. I'm going to be down the GC a fair bit. Won't be long before i'm moving down there i guess.
knore: you gotta go all the way to the f.ucking airport to pick up something that is *sent* to you? What a scam.. bloody terrorists, bloody sales tax, bloody bloody.
Hey Charly can you pick these lyrics, one of my fav bands :(
Give me the keys now you're too drunk to drive
You say it's all because of me
Tilting your head so you can catch my eye
Promising things I can't believe
Go the punk:
Would it make you feel much better
If it was you against the world
If you were an alien
If it were conspiracy
And would it hurt to live in comfort
If you found someone to trust
If you knew that you were with us
If we shared a common goal
But you will isolate, alienate
No one can appreciate
The poor miss understood
Can you see that I don't care anymore?
Do you ever stop to listen
Are you a martyr for your pride
Does it makes you feel much better
When you are an alien?
