I should be getting the 31 at least tomorrow night.. but its going to need a few things done before its on the road. The diff replace is going to cost a bit more than i thought, so 'project get skyline same colour' may have to be on hold for a few weeks.
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
evenin' all,
Question about the hybrid intercoolers....why does everyone shitcan them???
I have been looking around for some bad reviews, but can't seem to find much info at all. What's the go...are they leaky? poorly made or what?
Or is it the fact that they are manufactured in China?
Anyone got a definitive answer or is it all just heresay?
Hi Warrick
yeah I would like to know too.
When I was discussing with Gavin Woods the future mods for my car in regards to the power I want to acheive, he said not to touch the Hybrid as it didn't flow well enough for high powered cars.
He said it was good for up to 200KW but after that it just doesn't cut it.
So consequently I am madly saving for a new Trust intercooler
Hmmmm....Ok, well from what I have read on this forum, Gavin knows his shit.
So these "Hybrid spec" intercoolers (apparently made in the same factory), such as the ones mindflux is trying to do a group buy on are essentially the same thing I presume, and in that case to be steered clear of.
the hybrid coolers are fine .. ive got one on the way, however if you wanna run high kilowatts, then you best go for something more expensive. i dont plan to hit 200kw so i feel one of these coolers would be perfect for me.
other peopple bag them because there cheap they assume 'if their cheap its shit; .. other people jump on the band wagon 'oh wasnt made in japan must be shit'
yamutha - im not 'trying' to do a group buy .. i have already got mine ordered, infact ive had it eveb before the group by .. i was just letting people know about these intercoolers as i know there is alot of people after these intercoolers.
baah ill explain after i get away from the TV
bbs
200kw is all the hybrid can cope with ? even the stockie can do better than that most of the time.
for up to 300rwkw or so even the GTR cooler is all you need.. "all over again".. GTR cooler, custom stainless steel piping.
Generally the Trust I think is "the" best regarded cooler in japan.. the others come somewhere after that.. HKS isn't bad either, although i'm biased :rofl:
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
