  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Also when your breaking from doing 170 (this was on a legal drag strip) and your breaks start to shudder .. what does that mean?
FARK... Thats a low 13 sec 1/4 mile time there... Had no idea your car was that fast...
Shuddering brakes: Excessive runout on your rotors...
Solution: Machine the rotors or buy some upgraded DBA rotors...
Be warned if you only machine the rotors the shuddering will return...
Yeah WTF were you doing? I was trying to catchup to MJ I said it once and I'll say it again 90% of AUSTRALIANS CAN NOT MERGE! Bah had to swerve in front of that Z4 to frigging miss collecting a 4x4 stupid thing!
yeah ****ing hell man im so ****ing pist off
i was going to catch up to you .. and then all of a sudden that ****ing car would not merge in the merging lane so im ****ing down gearing and the wheels kept spinning when i down geard
then in the ****in 100 zone all the cars come to a halt so im trying to ****ing get aorudn them then they start moving but so slow .. so i go to take off and i have to down gear again and for some reason as i down geard it just locked up almost threw me side ways ..
im like **** this i wanna just get on the high way so i throw myself onto the painted island shit and over take the cars on the inside and this ****in car as im trying to get on the on ramp decideds he wants to get on too .. and then i cut him off and hes all up my arse and the car infron is doin like 20 on the ****ing on ramp
i was so going to ****ing loozse it .. ****!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
so i get home after grinding half my ****ing gears, and the diff jumping .. to find my ****in azenis are ****ed up due to having to lock up and all the down gearing, i swear to ****ing god im ready to ****ing murder someone
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
