  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Strutto - any chance (when your fee) we could catch up anf get you to look at the wiring for my headlights, it appears a connection is loose so my headlights like to turn themselves off while im driving :)
its cool if you dont wanna  just let me no yeah?
Maybe he can give you some english and grammar lessons while he's there:D j/k
wados - its not me personally that has them for sale, ..
but i am under the impression that there are a few for sale ($450 + postage) .. so check the thread and you will see a mobile number for 'AVI' ... give him a calla nd he will let you know, just say you clalin about mindfluxs group buy numba 2
and he can give you all the info you need
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
