  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Strutto - any chance (when your fee) we could catch up anf get you to look at the wiring for my headlights, it appears a connection is loose so my headlights like to turn themselves off while im driving :)
its cool if you dont wanna  just let me no yeah?
Maybe he can give you some english and grammar lessons while he's there:D j/k
wados - its not me personally that has them for sale, ..
but i am under the impression that there are a few for sale ($450 + postage) .. so check the thread and you will see a mobile number for 'AVI' ... give him a calla nd he will let you know, just say you clalin about mindfluxs group buy numba 2
and he can give you all the info you need
