  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
there were a couple of windows ftp servers that were really easy to hack a while back but I'd say they would be all patched up by now.
i took a shot of my two skylines this morning.. what a lovely sight.. well except for the funny coloured doors.. ha
You will have to paint a couple of panels a different colour so that the R31 fits into Team //ulticoloured Skyline :(
It was a truck that hit you wasn't that what you said ? I will put up a pick of your side skirts on my line WHEN it finaly gets done!!
