  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
still got 80 posts till I catch them though, might have caught up to them by quitting time, but then again, quitting time might not be that, might be clean out desk and see ya later time, FARK me crap ok fine that is it, I'm off to work!!!!!!!
Back from lunch!
Nah Pred not explosive...it's a solvent-free tank lining compound...just gets damn hot when it cures.
Strutto, yeah can still get cheap tolly....just haven't looked at it as the logistics of the last lot were a nightmare....I've still go 40L that hungry6 paid for...he's always busy when I need to drop it off though.
I should only deal with 200L's in future :spank:
