yeh, james, warwick and myself were behind the asian dude in the 34 with the GT wing. Dont think he knows about the system or something but yeh he was driving pretty slow and the car in front of him awas pretty slow too. I dont know tho it just felt more cruisy and like, me just recovering from the ding i put in my car, i wasn't exactly trying to be speed racer. Just trying to learn the limits of the thing.
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
if i had lotsa money id do it to a 34 GTR, and put a blower, with forgies and good rods. They got the same engines in the states making 1000rwhp on stock internals, imagine tuff internals and big PSI......
I can't believe you guys got lost again :)  Blame it on the person in front of you for not keeping a Skyline in his/her mirror...
i was trying to balance myself between the car in front and my rear.... dun know who the heck was driving so slowly behind me and i was highbeaming the driver in front of me, telling him to slow down...
buddy system not working too well that time.... Ska would have been pissed ;)
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
