  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Just tell him off Erin, so he doesn't do it again.
Got a couple of PM's from the guys about doing a group complaint to Christian, but I think that is too harsh.
Just a gentle wakeup call should be all that is needed :stupid:
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
