  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
hey ska i got some nice green paint for you
Cool I am looking at going a bit green crazy and painting anything plastic green :( so yeah I dont mind:D You gotta get a airbrush and get some practise in and do the hulk on my bonnet :D
HELP TO FIT IT??????.....you bloody great GIRL!!!.....it's a 15 min job!!
BAH I own 3 tools, 1 phillips head screw driver, 1 small shifter and myself. How am I supposed to fit it with any of those, none are usable! ;)
nah ska i know your there you get my 2nd pm??
Sure did and will give you a burl if I am over your area, but will be from public phone as I dont own a mob phone :D
NNoooOOoooOoooOOoooOoooooo............
Yeah but you know what they say, you just cant keep a good whore down! :D
hmmmmm it has started to work already I just did 4 posts in one! These anti-whore patches must be working :D
Kids are awake, thank god for 5 disc dvd player, I can stick in finding nemo, barbie swan lake, cat in the hat, brother bear and just hit play :( then I go back to bed, if there are any probs my daughter knows to get me :D bit lazy I know but it is just so I can sleep a bit more and then make them brekky without them hanging round my feet ;) esp with bacon & eggs, dont like the kids hanging round cause bacon splatters :D
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
