  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
interview wasnt too good..dun think he liked how old i was and one guy there said dont work here cause its shit..so yeh thats given me my answer i think
bAHBaHaha haHha hah aHHA H HH ahHAH HA HA h h AH AaAaaa dun work here cause it's shit?!?! either he really friggin hates the place or really loves it an dun wants to be replaced!
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
