lol ... this aint getting very far.. we could suggest 50 different suburbs around brisbane and everybody would have a reason for not going there.
i reckon just there, its near a mountain.. there is a view.. if its shit we don't get there next time.. simple.. but its different at least
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
adrian IM ON THE NORTHSIDE OF BRISBANE ABOUT 20MINS OUT OF TOWN. HMM ON THE WAY TO NOSSA WAY U GO UP THAT HWY TO COME PICK ME UP . LOL
Tell you what... If you can get to the meeting spot... You got a ride with me... Same goes for you Jaqule... But I aint going 1/2 the way to Noosa to pick yas up just to turn around and head back into town...
You do realise I live on the Gold Coast right?
furry Muff , I will make my own way PM details pls pred
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
