  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Funnily enough I've been think that for a while now, always been a dream of mine to be there for that...
well I am serious I am keen, I have two paid overseas holidays owed and Brazil is looking very good
Interesting idea, should be explored further... //GC goes brazillian...
Safety factor worries me a bit to be honest.
Yeah that worries me too,
I have a couple of Brazillian penpals and they said they will look after me and anyone who comes with me
