  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Nick,
hahahahahah, I Owned you at pool last night. I won every game we played, giving me a perfect winning streak against you. Games won by me 100% games won by you 0% lol. And I was so looking foward to seeing one of your so called patented "ass whoopings" or "smackdown fests" where you win like every game off the break for three hours running. But all I saw was you beating people who were too drunk to hold the que properly, and you screaming "SMACKDOWN" when you beat them. Might I add I was very dissapointed that your pool game doesn't stand up to the amount of trash you were talking. If you didn't mouth off so much I would have commented that you play an acceptable game. :thumbsup:
Yep, I'm going for dinner at the local bowls club, and then I'm settling down for a nice relaxing night of bingo. Did I tell you that I got myself some of those lucky trolls, with the whack hair and all. I have a good feeling about bingo tonight. I got my felt pens, and my ID, and I've ironed pleats down the front of my jeans, and I've got some brill creme for my hair..........
I think I'm as ready as I'll ever be.
:thumbsup:
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
