  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
mmmm mabey i dunno, i gotta swing by somewhere and pick up some er, goods, im not goin on the run tonight, too tired and as has been said a million bloody times, my fave passenger is busy
Goods eh?
Yeah I'm not sure about the run either...
No fave passenger? BOOO...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
