  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
YEAH! MY PAGE!
Warwick hows da pod goning?
podi is going well.....overfueling/popping shit over 5000rpm thing has gone.
I have "modofied" (read: butchered) the stock airbox to make a type of cold air partition/intake....pretty happy with it......AND, I have my sucky fu(ky noises back :thumbsup:
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
