  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
i'm too sure exactly what did happen as i was up ahead.. but apparently he overshot the corner and went off. All I heard on the radio was "somebody come back! somebody come back! " from charly... which wasn't ever going to be good.
Few cars went back to help, but don't think there was much anybody could do to get the car out. Least he was ok.
We just went through and picked out anything I could paint green on my car and then it was smooths idea to to the whole fully sic new SAU flier body kit to owned :D got some great pics :rofl: at least he has some to hand out now :rofl:
WTF:
Ska, you do not have permission to access this page. This could be due to one of several reasons:
  1. Your user account may not have sufficient privileges to access this page. Are you trying to edit someone else's post, access administrative features or some other privileged system?
  2. If you are trying to post, the administrator may have disabled your account, or it may be awaiting activation.
yeah, makes sense. Thanks for the radio too ska.. great thing to have, very entertaining. Going to have to get one..
and a whole new brake set.. mine were fading massively. Coming down if i wasn't very careful could have easily lost it myself.
