what are cops even gonna find on here, that we have skylines with mods and drive around in them fast sometimes.....................wow like they cant work that out without bothering everyone on here.gee, we dont go sussout there cop stations to ce if they are currupt or anything.
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Yeah would love to go to a defect cruise...unfortunately I wouldn't even be able to make it :) damn car has finally shit itself...will turn but not fire. It's all looking to be like a broken wire somewhere...affecting coils and firing. Can't be arsed looking for it now!!!
oh.. maybe you missed it when we were talking about it earlier today adrian..
We were thinking like SAU, "Copsaustralia.com" where they go on there and discuss the latest defect techniques, swap brag stories how they defected a guy because he was missing a shift pattern on his gearknob, the best spots to buy doughnuts in town, etc :)
We were thinking like SAU, "Copsaustralia.com" where they go on there and discuss the latest defect techniques, swap brag stories how they defected a guy because he was missing a shift pattern on his gearknob, the best spots to buy doughnuts in town, etc ;)
Nah I was there...
Not to sure on whether the cops around here are bright enough to use a forum... Ever seen them at the station with the old one finger typing?
Kuntstable Mystique can't even find the post reply button... :)
Yeah looks like an electrical fault somewhere...been getting worse...past 2 days I've had a dead battery. No load when the car is switched....so not being drained?
Alternator runs car fine when battery is disconnected? Thinking either the battery is completely shite...or there is a strange charging issue.
Also managed to make the car idle funny and lose a cylinder by wiggling some of the ecu leads today, so it's like the wiring has decided to die!!!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
    • Hello everyone, I am happy to join you.
    • Whereabouts are you, that looks exactly like Akira's old car....
