  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
i can? i was trying to keep up, crystal (passenger) was jumpin out of her seat! hahha
in my view, any gal who can handle that beast in the corners and darkness qualifies as a good driver.
newsflash: everyone was trying to keep up too :D
cant wait to go to skidpan. if i loose it in my car thats it, dnt know how to gain control. only had it for 8 weeks *my first turbo car!! Yipee!!*
you will LOVE the skidpans... been there twice as spectator...
did not try becos i dun wanna get diesel in my engine bay... might be changing my mind soon though..
and oh yeah, you will understand your car so much more when you are done with it .. trust me :D
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
