  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
dial up is frustrating when in postwhore thread :D
anyhow -
my car is making a noise from the rear passenger side
not a wheel bearing noise it isn't a metal sound - more like a squealch/squeak
think there are 2 noises as 1 stops when handbrake is slightly on (prob pads are glazed) but the other noise is louder
driving me crazy
