  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Cut wire #53 on the ECU harnes to disable the 180 kph speed cut. The wire is yellow-green with a silver trace. Insulate the bare ends with tape. Maybe wire in a switch to enable / disable the speed cut.
Note:
This impacts the HICAS diagnostic mode - will not exit the diagnostic when 10kph is exceeded.
This mod is only for legal off street activities - ie drag racing, circuit racing, speed trials (eg the annual Ohakea trial) or if you live in a country where the speed limit is over 180 kph.
It is up to you to ensure your engine does not run lean at high speed - you will loose your engine if it does.
courtesy: http://www.overflow.250x.com/
Ok...what's with the birthday crap....you and I have the same b'day Erin....so following that logic.....It's your birthday too.....what's the go??....or am I missing some joke?
I dont know I just read a post saying it was your birfday and I didn't wanna miss out on the fun!!
But if it's my birthday too.. I'm kinda missing the FMIC i've been begging soo long to get :P
14.6.. but it had a blown motor... it was ticking madly when i got out for my time slip... should have done a mid 13.... thats wat i was hoping for....
id be happy with a high 12 now...   should do it... just depends on me really
And the gearbox :P
The car looks sweet though. I like simple; tint, lowered but not extreme and a good set of rims. Its a winning combination!
can you tell santa or the easter bunny or whoever is responsible for birthday pressies that I would like a FMIC too please, as well as a 3" dump pipe....thanks :)
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
