  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Cut wire #53 on the ECU harnes to disable the 180 kph speed cut. The wire is yellow-green with a silver trace. Insulate the bare ends with tape. Maybe wire in a switch to enable / disable the speed cut.
Note:
This impacts the HICAS diagnostic mode - will not exit the diagnostic when 10kph is exceeded.
This mod is only for legal off street activities - ie drag racing, circuit racing, speed trials (eg the annual Ohakea trial) or if you live in a country where the speed limit is over 180 kph.
It is up to you to ensure your engine does not run lean at high speed - you will loose your engine if it does.
courtesy: http://www.overflow.250x.com/
Ok...what's with the birthday crap....you and I have the same b'day Erin....so following that logic.....It's your birthday too.....what's the go??....or am I missing some joke?
I dont know I just read a post saying it was your birfday and I didn't wanna miss out on the fun!!
But if it's my birthday too.. I'm kinda missing the FMIC i've been begging soo long to get :P
14.6.. but it had a blown motor... it was ticking madly when i got out for my time slip... should have done a mid 13.... thats wat i was hoping for....
id be happy with a high 12 now...   should do it... just depends on me really
And the gearbox :P
The car looks sweet though. I like simple; tint, lowered but not extreme and a good set of rims. Its a winning combination!
can you tell santa or the easter bunny or whoever is responsible for birthday pressies that I would like a FMIC too please, as well as a 3" dump pipe....thanks :)
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
