  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
tell him bout the really cool 33 gtr u noe...hahaha...maybe he'll want it
that's outa his budget... anyway... i would really like to see you keep it till track days... dun you??... i mean .. its been built for tracks already...
yea well if i do sell it now n i do get my pr...then i'll have an even better track car...if u get wat i mean
i do... just hope that you will at least bring it down to track once.... i noe you have been wanting to but becos of the farkin weather and all...
