  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
hmmmmmmmmmm gonna measure up my racing stripes today :) buying off Melv, and was waaaaay cheaper than I thought :D mUAHAAh AH AH ah AhaaAaaaa GO RICE!
I presume they are gonna ge green??
have you got the vinyl yet?
you do know you can go to a vinyl/signwriting supply store and just but the stuff in rolls you know......
Did you know MELV is a signwriting store :) doubt I could get it cheaper, plus I'll support other SAU member even if it does cost a bit more, den I might get a ride in da wicked GTR :D
hey Cyrus where abouts is his shop i have to get some stuff cut out
Somewhere down here, dun know exactly, he does stickers and neons, very very nice gear! Got his email if you want to contact him...........?
no...I didn't know that :slap:<-me
Yeah I think it is because it is somewhere we have already been before, so people will think it is boreing, but I have done it a couple of times and each time it gets better as I get to know the road better, plus I wont be going, got"told" that I have my kids over the long weekend, which I am stoked about, just wish I was asked not told, I would've said yes in an instant!
