  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Stop hitting on Sam you lot...  You'll scare her away...
Warwick will gladly satisfy any of you in a relationship kind of way... :D
sure....there's always room for one more :crazy:....all these spare orifices going to waste....
Who Posted?
User Name Posts
chaos 1643
Ska 1227
strutto 1002
GenesisR32 997
predator 958
Nexus9 945
yamutha33 820
SmoothLine 747
mindflux 515
NA_R33 515
EVO83 500
BelGarion 453
jaqule 435
Charly 287
NismoGirl 273
owned 237
FYN33 227
jlnewton 130
666DAN 127
Nismo_Boy 122
MJ 121
MM2death 110
twoquik 95
rb26dett 82
Zoix 68
wados 59
krawler 48
PlATiuM 45
TeamKrazy 43
pimpspec 30
R33 GIRLY 24
knore 20
Spooks_Skyline 18
nismoman18 17
GOR33 16
Skyrine-Dave 13
R33Steve 11
The_Paladin 10
stuntgirl 10
33NIZ 10
Shane 9
CGB_R32 7
Nizmo 6
GTS-t VSPEC 5
gatty 4
MotoX 3
51jay 2
Bobjones 2
DJ_L3ThAL 2
slip 2
skiliner 2
Mase 2
PTR33 1
Spectrix 1
Mr GTS4 1
Anna32 1
avalonea 1
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
