  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
i love living!! to be honest, i never had the best childhood, always got shit from people never had alot of friends, used to be an arrogant little shit, but once u start enjoying, thats the point where u change and go hang on, im me, no one else, y pretend im something im not and then go well this is me what am i gonna do? set goals, the biggest one is HAVE FUN!!!
First beer down time for the next one
Oh man, i remember the day i hopped in mine, OMG it was like my first Christmas times by 10, i was with mum and she said she has never ever seen me so happy, i had a grin ear to ear all the way home, got home and polished and polished, couldnt drive had no licence but polished and polished, damn she was shiny for a while! 2nd happiest day of my life!
i always get depressed when i go out, cause i see chicks and get boosed and just miss Kate and it sucks so i dont go out much unless im with a big group of mates.
I've been there before.... things will be different when she gets back... hopefully for the best...
I think the best test of a relationship is being apart then coming back together... you will know if its real man :D
    • I was 99% sure the standard one is long enough to get there, you might just have to change the throttle orientation. If not, I remember someone having used an r31 cable instead, but that is probably harder to find than r33 by now...
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
