  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
the problem is i have 4 ISP email accounts.. and all of them exhibit this problem..
its always happened.. sometimes it works, sometimes it doesn't.
Well dere's your problem, most ISP wont allow relaying from other IP's but they're own so if you trying to send from ISP1 using ISP2's mail server you'll find ISP2 wont let you because you have ISP1's IP :) confused yet, I am! :nowigetit
wish my job was like that. NO seats for 7hrs at all. 7hrs on ur feet sucks.
Yeah I know what that's like 2 years doing the 10pm to 6am shift at servo's :) bah the job sucked but was waaaaaay better than being on friggin dole!!
too bad we just had a secritary job go here I was gonna tell NismoGirl to apply but it went to on eof the bosses mate daughter :D everyone who has a job here has it because they have known someone here :) This place is really great to work for!
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
