  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
jaqule..im going with John tonight
Is it posible to meet you somewhere and hitch a ride ?? If not it's ok I will go down the coast on the train and drive back up in my bro's shit box , but would prefer a ride
F*ck, I don't have a clue, coz mr defectabe himself posted somewhere else.  Check it out and see.   Bugge it I've still got everyone's number.  I'll just call them and tell them the place has changed.  Glenn ideas?
changed to where??
