  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Uhmm yeha guys i better sya something ..
I did invite anna to come, she is a ncie girl when shes on her own .. i did tell her the time wa 8.30 ..
and she called me at 9pm saying that shes on her way with on bail and 2 own you .. i was kinda a bit like 'hmmm' because i know there not liked much by people on here. but as you can understand i couldnt tlel them to **** off.
they only reason i stayed back was because i did tell anna i would wait, (again.. she is a ncie girl when shes by herself)
And when we got to the shell .. she did say 'oh we didnt realise we were going down south so far' .. :S
I can sympathise wiht you guys because i completly understand, but you need to know i was caught in an awkward postion ..
if i look at it from everyone elses perspective , i can understand you telling them to get ****ed, (or anyone) ..
as you know i cant really comment on this situation as its awkward for me ..
however i will be saying a little somethign to anna
somethign along the lines of '8.30 means 8.30, not ****in 10 past 9'
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
