  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
had a rolling run against Ska that night we cruised to Wellington Pt, and it was pretty well neck and neck, and from memory I think the kerb weight of the two is about the same 1300kg give or take, so they are a pretty even match stock for stock, as long as it's not froma standing start :(
Warwick, the eating place that i hang out at is in Chinatown. THe place opens till 2am everyday and food's great. James and I are regulars there.
and plus, his chopstick skills have improve tremendously :(
Cybercity
206 Wickham Street
Fortitude Valley
QLD 4006
hmmm, I think you might have to take driver skill into that, can't see a stock Rex neck and neck once third is reached in both cars
Cybercity
206 Wickham Street
Fortitude Valley
QLD 4006
cool...i will have to join you sometime, maybe bring the wifey....we bo th love asian food of just about any variety
and James & I love having more company. John was our lastest victim... hehe.... but his chopstick skills are even better than that of James!
wassup guys.. just got up and browsing thru history....
i hope everything survive thru this weekend. Squizz called me yesterday and warned me abt cops being swarming all over the place, esp major highways.
yep they sure are I have been breath tested 3 times this weekend and I have hardly been driving anywhere
cool....my choppy skills rock...the missus can handle herself pretty well also
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
    • You can set hard reserves on your battery system, and it can't be discharged past that.
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
    • Hi Jasmine. How's the war going?
