  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Neil, go read up on the Forced Induction Performance and Maintenance threads. They are pretty good though you gotta learn to filter out the rubbish advices by noobies.
In QLD, i know that guys like Strutto, Jay51, Squizz, Slip and JLnewton knows their stuffs. Also, Tze (my neighbour) is pretty knowledgeable as well.
I learn some of my stuffs from Tze and mostly by reading.
The true king in these forums would be 'sydneykid'. he's our god :(
i put in some offers on some second hand ones i found on various forums
sorry.. i forgotten to include these guys in my PM to you. Their prices are VERY good and its brand new from Japan as well. Lotsa guys here are ordering from them as well.
http://www.greenline.jp/
http://www.nengun.com/
13's my ass!! be lucky if i break the 14's!!
running 11psi w/ boost controller.
13 is very possible, Sam.
you have got FMIC, PowerFC and boost Controller. Your standard turbo is good for maybe 1.2 bar. If you got the right traction and launch is properly done. You might just break into the 13s.
sam a lot of Na 33 run 14s you get yours tuned right and u will run 13s easily
ben, that's impossible. NA 33 do not run 14s unless we are talking abt John's car but he's got happy gas.
my car, completely stock, manages only 15.98. i have got a rb25de inside and my car is 100kg lighter than the 33s.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
    • You can set hard reserves on your battery system, and it can't be discharged past that.
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
