  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
yeah.. seriously... imagine your gearbox without oil.
it would be farked the moment your hit 1st.
well i got a story on that
my aunt has a cq60 merc
and she took it to be serviced
and they never put gearbox oil back in
she then drove half way to dbn (+-350kms)
and then it seized
she then said "i tought i could hear something whinning and getting louder"
yes i will take 10litres pls
get Rozz to try it as well.
the specs for turbolite are:
TYPE OF USE
Specially designed for high performance engines
All gasoline or Diesel engines, Turbo or naturally aspirated, multivalves, with carburettor or with injection, with or without catalytic converter.
Suitable for all types of fuel : standard, unleaded, Diesel fuel, LPG.
All driving conditions : City, Road, Highway.
PERFORMANCE
STANDARDS ACEA A3 / B3
APPROVALS API SL / CF
VW 505 00 / VW 500 00 quality
Mercedes Benz page 229.1
* The new standard API SL is more stringent than API SJ in terms of ageing resistance (average drain interval increased), requires anti-oxydation properties that maintain a constant viscosity avoiding sluge and deposits in the crankcase, anti-wear properties and dispersent power
The synthetic base stock provides high lubricating power and protects perfectly the engine while in intensive use on road, highway or in town.
The high performing anti-wear additivation results in reduction of engine internal frictions and increases life duration by wear reduction.
SAE 10W-40 viscosity grade is fully adapted to recent gasoline and Diesel engines and ensures easier starts.
Very efficient anti-deposit and anti-black sludge power which keeps the engine clean.
Anti-oxidation, Anti-corrosion, Anti-foam properties.
and then it seized
idiots.
that's why i like to do the servicing myself. at least i know WHAT kinda oil is going in and i can take my own sweet time.
i usually leave the engine oil to drain for 2 hours :(
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
