  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
I thought you couldn't run more than 14psi on a standard R33 turbo.
That's what I'm aiming for. If a family sedan can do it... surely I can :D
You can run as much boost as you like... It's just not smart and doesn't make your car any faster...
Least you called it a sedan... :) Not a 4 door...
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
