  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Wassup? Just got home from a quiet night beating up on poor lasers running 15 psi :D
Tsk, no no no.
He was running 7psi, the same as he always does. The reason I _couldnt_ run high boost was because it was hitting 15psi and just pinging its head off.
The adjustments I was making on the side of the road was to get it to sit on 10psi, but the damn thing was still spiking too high.
Ah well. Poor Brutis. SOHC, 8v and a computer that has all the power of a small asian kid with an abacus. Yay 1982!
Tsk, no no no.
That's the forum equivilant of the losers driveby :D
Tsk, no no no.
My apologies Andrew! Still before you started playing with it I could not catch you, only keep up :D
I eventually beat him, eventually, We did the whole I am going to try to follow you when he took off and seriously could not catch him, but he made the fatal flaw of fiddling and made it worse, then and ONLY then I ONLY JUST was beating him, ONLY JUST!!!
ner ner, I did a bigger skiddie.
:kick:
    • Hey everyone. Is there a way I can get the original window sticker (maroney label) for my 1995 R33 GTST? I doubt I’ll be able to ever get it but it’s worth a shot to ask
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
