  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
goodam it. Matt!!! need to talk to you!!
Got ur msgs, its all good. You can now chillax :)
Let me know if you want to meet somewhere to buy them or just fix it up next time we see each other... Even if its over $100 its still a bargain!
Aiya, id even pay $100 just to hear ska sing :D
thanks for the tip...I'll be heading right past them.....what speed do the radar guns become innefective at?:D
I know the ones in the sydney tunnel come up blank if you're going over 320kmh...
This year... as of mid march, three or so cars have been snapped at speeds the cameras couldnt read...
