  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
as I have stated a number of times on this forum........derrrrrr....I'm not too bright....
I was just informed that MSCII starts at ~7PM....not 7AM......In which case......I CAN COME.... :headbang: Yessssss!!!
Oh dear god.
Warwick.. you scare me sometimes.
We got this late 20's ish brunette who gave a smile, no wave but a smirk then a shaking head :(
Then two early 20ish girls catch us in a TX5 I wave got a wave, then a shun, then a smile and wave from the driver, when shown a mob phone, they happily provided one and we had a great chat, THANK YOU PLATIUM for use of his mob phone!!
WHO IS YOUR DADDY!
WHO IS YOUR DADDY!
And.....? There has to be more than just that...
