  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Night Erin...
Have fun at work tomorrow...  That goes for all of you :(
Ska...  Talking to chicks on the phone does not = picking chicks up...
Or I picked up a chick on the Austar help line the other day :D
Yeah but were you driving down the highway 10:30pm at night doing 120kms an hour and making wierd faces at that austar help line chick? Did she have to count out the numbers to the help line using her hands, did you talk to her about her weekend and what she is doing next weekend..............
Ok so I didnt pick them up, I WAS SOOOO SHOCKED that 1. the driver had some guts to drive that TX5 or try to :) and 2. they actually gave out thier mob :D
Ok so I didnt pick them up, I WAS SOOOO SHOCKED that 1. the driver had some guts to drive that TX5 or try to :( and 2. they actually gave out thier mob :D
Nope...
I was here at home... Recovering from the Mad Easter Sunday root I had... :)
An den, well I am a gentleman so I asked them what they were doing next weekend and invited them a seat in my car, to which I got a solid maybe, girl talk meaning probably not in a million years :(
Had a fun night though coming back :D
Ok so I didnt pick them up, I WAS SOOOO SHOCKED that 1. the driver had some guts to drive that TX5 or try to :D and 2. they actually gave out thier mob :)
Damn! Thats some hot stuff right there!!
Maybe that post should be moved to a more suitable area?
