  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
no worries :thumbsup:
here is the post if you are interested
http://www.skylinesaustralia.com/forums/sh...3863#post773863
and a copy for those who can't be bothered clicking on the link ....
I will give them the benefit of the doubt, it is hard showing up to a group of people you don't know and being open.
People handle that kind of stuff differently, people say I am Aloof when I first meet them, all I am doing is trying to see if I can work them out first.
And having a car that has been targeted for Theft (i.e my old 215 RWKW S13 had been attempted to be stolen twice) I am very hesitant about answering questions about my car to people I don't know.
As I said I will give them the benefit of the doubt, if things don't change then I will bucket them with you :D
I completley agree with anna, i have already had a little chat with her about it, i dont think sau should be like this. I did say that mark should at least sign up and say gday, i understand that he is busy all the time but at least introduce himself.
The first couple of cruises i nobody came up and said hi or anything and i also felt asif there were seperate groups in the cruise.
I am a really quiet guy and i hope ppl dont ever take me the wrong way.
I dont think we should descriminate against anyone i am keen for anyone to come on cruises.
We all might have opinions about ppl but please keep you opinions to yourselves and not
bitch about ppl.
bitch about ppl.
:werd:
I think everyone that can make it should come to the dinner on this Thurs , that way it is a total social event , no cars , no groups and in an eviorment where we can all talk and get to know each other , without having to worry about where we are going who is meeting who .....etc .
Just remember take care of yourself and each other
my 2% of $1 AU
Thats it!!!!!!!!!!!!! Im done with my current job... it isnt heading where I want so everyone can just **** off!! Im sick of this shit...
/end rant takes deap breath...
Testify brother :angel:
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
