  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
AH HA See another male has learnt that it is easier to roll over and die than to argure you point of view with a female, it just does not work they always end up being right!
:boohoo:
depends if you like them or not, if you like them then you can not win.
And if you don't like them who gives a shit what they think (learnt from Misogyny101)
So much hostility,
Why cant we be freinds?
I seen ya I seen ya I seen ya 'round for a long long time
I really I really I really remember when you drank my wine
I seen ya I seen ya I seen ya walkin' down in Chinatown
I called ya I called ya I called but you did not look around
I pay my I pay my I pay my money to the welfare line
I seen ya I seen ya I seen ya standing in it everytime
The color the color the color of your skin don't matter to me
As long as as long as long as we can live in harmony
I kinda I kinda I kinda like to be the president
And I could and I could and I could show you how your money's spent
Sometimes I don't speak right
But did I know what I was talking about
I know you're working for the CIA
They wouldn't have you in the mafia
Hey warwick what are your plans with that poor excuse for an airbox I handed over last night? :thumbsup:
I'm just gonna use the lid and do a slightly neater job than the first one I did and hopefully have it seal a bit better
/me throws a slice of cold pizza at cyrus
Catches it and swallows it hungry dog style, without laying a single bite mark in it GULP! :D mmMMmmMMmmMMm pizzza sooooo hungry, doh got leftovers for din dins tonight :thumbsup:
So much hostility,
*dances* just so cyrus doesnt feel lonely singing by himself :thumbsup:
yay there saying thursday my car will be ready, after the aircon regas and wheel alignment is done :D
Thursday what month?!?! AND after all that last night I STILL forgot to get that bulb off ya!!
Hey can you PM that mob number and names plz :thumbsup:
half the time ya dont really watch the times ur racing the car beside you, depends if your out there tryin to set ur car up, or just have a few fun runs and line some mates up
I'm there for a before and after shot, tomorrow being the before obviously :thumbsup:
Oh and line some mates up too :D
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
