  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
mmmm i didnt really sit down with gavin and sort much out, which is kinda annoying me cause i wish i had, ive probably got a lot of the wrong stuff to put on, and gonna wind up with an undrivable car ie too slow off boost and too slow to come on boost ect
yeah he definitely told me a couple of things I didn't know about various components, and why it is good to go for type A instead of Type B
I would have made a couple of mediocre choices if left to my own devices
well urs will be done before mine hten cause im still waitin on parts to come
nah mine probably won't be good for at least another 8-12 weeks, as I am buying the parts when I have spare money, not gunna use the credit card, except maybe for Gavins labour and tuning cause once I have all the parts I don't want to spend another month saving to pay for the labour whilst all the parts are losing value sitting there :)
I will show what parts when it's done Warrick :D
Hi all :wavey:
still no parts, yet they were promised to me today :) dad is getting cold feet about me having a "fast car" and being an absolute idiot and its looking like it wont be done before my mechanic is due to leave oh what a great day.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
