  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Toluene is produced during the process of making gasoline and other fuels from crude oil, in making coke from coal and as a by-product of styrene. Toluene is used in the production of nylon, plastic soda bottles and other organic chemicals. It is also used in making paints, paint thinners, fingernail polish, lacquers, adhesives, and rubber in some printing and leather tanning processes.
I'm saving my last little bit of Toluene for tomorrow... :headspin:
