  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Glenn - Yeah I was talkin bout it yesterday arvo (couple hours ago) and he said he'd race me there, I asked if that meant he was going, but he did not respond??
hmm... he never mentioned it to me....
he called me this evening all excited and asked if i found a meeting spot for the brisbane crew for thursday food feast. and told me abt the new cb radios and how he is keen on trying them..
but no mentioned of Willo.
carefull what u wish for cyrus :D
Well in dat case:
1. 3 inch tubo back with high flow cat + install
2. FMIC + piping + install
3. front and back strut bars
4. In car UHF with antanne + install
5. Greddy Profec e-01 + Greddy e-manage + install and tune
6. Short shifter + install
7. Racing stripes (From MELV)
8. Green neon kit (From MELV)
9. Ajustable coilovers
10. front bar + side skirts anny BUT 400R + repray and fitting
11. misc internal plastic sprayed same green as used on exterior
12. high flow turbo or garret turbo
13. new clutch
14. wider tyres
15. wide body kit
but last ones are just wishes, but that is my shopping list at the moment, in that order I want them :P
hmm went quiet in here
Just arranging my shopping list for you :P problem is if you buy me any of the really expensive stuff I'll feel really bad, cause that is money you could be putting away for your own line!!
Ska... Your putting performance before rice... That's not like you...
Rice is just so much cheaper :P
Rice will prolly get done first cause it is the cheapest $80 for the racing stripes and $200 for the green neons from MELV :D
i tell myself i would be putting money away for my line but im just gonna wait till i start the new job..use the money i make at maccas for things when i move in
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
