  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
:@ i hate uni students why if something doesnt work or go as bright or quick as they want they crank the f**king voltage more :@ errr now i have to wire wrap 3 20pin IC's into this circuit board, either that or replace the whole board and solder in new everything :@ damn u people :@ i want a bludgy day not a stressful one
afternoon peeps :)
ahhh what a glorious way to spend a day off....
changed the engine, gearbox and diff oil....thought the line deserved it after the flogging I have given it over the last few days
tis quiet in here today :)
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
