  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
but i'm sure they can pass off as brother and sister right?.. both young looking..... cant really tell the difference anyway :P
ummmm....I don't know if you noticed or not Glenn....but she wasn't asian....how they gonna pass as brother and sister?:cheers:
how was the birthday party?
you missed out alot last nite, J.
we had SOme fun with little Nicky :cheers:
The party was ok, saw alot of people I haven't seen for ages, would have prefered being on the cruise, but little sisters only turn 21 once so what are you going to do. I am pretty sure I saw you driving along Milton Rd about midnight Saturday night, I was heading the outbound, you were going inbound. Either you or someone else with a black 32 with white wheels.
What fun are we talking about?
