  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
lol glenn.
I'm not sure wether to make myself a coffee or pour myself a bourbon... I don't know what I'm doing later tonight though.
come and babysit me :cheers:
make sure i study... the forces of SAU is too strong~~~.... :ghost:
